oasis4355
Member level 3
- Joined
- Feb 28, 2006
- Messages
- 67
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,286
- Activity points
- 1,801
Hi all,
I came out with a class C vhf amplifier for the last stage of my transmitter, referring to the image that i've upload, it suppose to have a 20dBm gain at 100MHz in S-param simulation with ADS.
However, when I've input a 100Mhz signal at -10dBm into the amplifier using a signal generator, not only it doesn't amplify the signal, it somehow makes my signal into -20dBm, when i check with a spectrum analyzer
What seems to be the problem? I've check the circuit on the PCB board, everything seems correct.
Please advice,
Thanks in advance
Please advice,
Thanks in advance
