Problems with Trisb, Trisa. !!HELP PLEASE!!
firesky1982
Newbie level 3
Newbie level 3
how to set trisa and trisb
I can not get the code to build corectly. Here is the code:
	ORG	0
PowerOn		BSF	STATUS,RP0		;Select file bank 1
		MOVLW	H'00'
		MOVWF	TRISB			;Set all PORTB bits as outputs (display driver)
		MOVWF	TRISA			;Set all PORTA bits as outputs (will be inputs in future version)
		MOVLW	B'11010111'		;Turn off PORTB pullups, prescaler to TMR0, 1:256 scaling
		MOVWF	OPTION_REG
this is the error message I get: Register in operand not in bank 0. Ensure that bank bits are correct.
If anyone can help me I have the same problem with all of my code with trisb,a.
MCU:16F84A
Thanks,
Garett
What you are getting is a just warning. TRIS registers and OPTION are in bank one, therefore, you need to set the RP0 in the STATUS register before writing to the TRIS OPTION registers. You are doing that, but the assembler is not smart enough and it still generates the warning.
However, the code will work, since these are warnings only. There must be another error message that actually prevents the build. Please check for it.
Make sure you clear the RP0 bit once you are done writing to the TRIS and OPTION registers.
try this:
ORG 0x0
goto Power on
ORG 0x4
(espacio para interrupciones)
org 0x30 ... o 0x40 ...o 0x50 (deja espacio para interrupciones)
PowerOn
MOVLW 0
MOVWF TRISB
MOVWF TRISA
MOVLW 0xD7
MOVWF OPTION_REG
... sigue el codigo ...
SUERTE! Good luck!!
ok, it builds fine but still will not program for some reason. I cant read hex code but the error is in the begining.
The fact that you cannot program the PIC may be an entirely different matter, related to the programmer for example.
I am sorry, I do not understand what you mean by not being able to read hex and the error being in the beginning. If there is an error, you will not get a hex file.
I THINK THAT IS EASY TO KNOW THE PROBLEM, AND THE PROBLEM IS A GAME OF BANKS TRY INCHANGE OF TRISA OR TRISB TO WRITE PORTA AND PORTB RESPEC.
AND BE SURE THAT THE BANK BIT IS IN THE WANTED, I MEAN IN BANK 1 FOR TRIS FUNCTIONS THATS ALL I CALL THIS A MAPPING TROUBLE.
i dont think you have a problem
you have to move your code below
org 0x08, and every thing will work all right
example
org 0x01
goto START
org 0x04
; intrups
org 0x08 ; HERE IS YOUR CODE
START
banksel TRISB ; SELECTS THE BANK IN WHICH TRISB EXISTS
CLRF TRISB ; SET ALL PORT B TO OUTPUT
MOVLW 0XFF
MOVWF TRISA ; TO SET ALL PORTA TO INPUT
END
