FreshmanNewbie
Advanced Member level 1
There is a Master MCU. Connected to two slaves (One slave is shown above, the memory IC). One is the memory IC. Other is an metering IC connected through the TI isolator part.
When I try to read the memory IC, I see data going. But the SPI_SDI line voltage moves between 3.3V and 1.5V. It doesn't go to 0V. This is only observed on the SPI_SDI line and not other lines.
I guess, since the TI part has the SPI_SDI (pin 6 of TI part) it as an output pin, it is causing some issues.
When I remove the TI part, I see the SPI_SDI line going from 3.3V to 0V. Can someone tell me why is this issue being caused?
I saw in TI forum - over here, there is a similar issue over here. But I am not convinced of the reason given in TI forum because I am used the right probes and tried. But still having the issue.
Is it related to drive level of the ICs? Can someone explain the reason for the issue.
