riteshjain_82
Junior Member level 1
hi to all
i am facing a very difficult problem....
i have make a project of "Remote Light Control With Dimmer"
uisng 89c2051 published on elektor july/ august 2003
i project is working fine but the problems are
1)after storing the desired infrared code...the kits working fine but when i turned it off and on again it doesn't start by remote..but start with s1 button..
and the ON/OFF code of remote is not worked but the brightness up and brightness down button works...
therefore i have to store the infrared code again and again when i turn it off and on
2)the r1 and r2 resistors are getting too hot and finally burned...i have to changed them many times...
kindly give the alternate sugesstion
please help me ......
