lord tyrion
Newbie
Has anyone used a spice model of memristor? I want to create a SPICE subcircuit file for the memristor, which I have found for the LTspice. I want to know how to convert the LTspicecode to WRSPICE compatible subcircuit format. I am using the model proposed in Joglekar's paper in LTspice (I have done the simulations for this code and it's showing results). Can anyone tell me how to write a code as I am a newbie to the spice simulation software and also in the code can anyone explain the differential equation modeling section.
The code is pasted here:
[moderator action: added CODE tags]
* HP Memristor SPICE Model
* For Transient Analysis only
* created by Zdenek and Dalibor Biolek
* Ron, Roff - Resistance in ON / OFF States
* Rinit - Resistance at T=0
* D - Width of the thin film
* uv - Migration coefficient
* p - Parameter of the WINDOW-function for
* modeling nonlinear boundary conditions
* x - W/D Ratio, W is the actual width
* of the doped area (from 0 to D)
.SUBCKT memristor plus minus PARAMS:
+ Ron=100 Roff=16K Rinit=11K D=10N uv=10F p=1
* DIFFERENTIAL EQUATION MODELING *
Gx 0 x value={I(Emem)*uv*Ron/D**2*f(V(x),p)}
Cx x 0 1 IC={(Roff-Rinit)/(Roff-Ron)}
Raux x 0 1000000
* RESISTIVE PORT OF THE MEMRISTOR *
Emem plus aux value={-I(Emem)*V(x)*(Roff-Ron)}
Roff aux minus {Roff}
* FLUX COMPUTATION *
Eflux flux 0 value={SDT(V(plus,minus))}
* CHARGE COMPUTATION *
Echarge charge 0 value={SDT(I(Emem))}
* WINDOW FUNCTIONS
* FOR NONLINEAR DRIFT MODELING *
* window function, according to Joglekar
.func f(x,p)={1-(2*x-1)**(2*p)}
.ENDS memristor
