Problems with IC5 0 - Bus error
aekn
Member level 1
Member level 1
Russia
1. I install IC5.005.. Program works but in log file i get Warning:
Fragment of Lof file
Loading seismic.cxt
ddsWhatsNew()
Incorrectly built binary which accesses errno, h_errno or _res directly. Needs to be fixed.
hiResizeWindow(window(1) list(278:50 1003:211))
hiResizeWindow(window(2) list(341:248 931:748))
Warning: Cannot convert string "-adobe-helvetica-medium-r-normal--0-100-75-75-p-0-iso8859-1" to type FontStruct
hiQuit()
hiDBoxOK(hiQuitDBox)
When I install IC5.032 it worked too, but I got the same Warning.
How to fix this problem?
RHLinux 7.2
All thats I made on PC P4 2.4 (North.) SIS655 GeForce 4MX440 AGP8 128Mb.
2.When I try install on other PC - P4Cel 2.6, Int865 GeForce 2MX400 32Mb, I got:
1. IC5.005 Installed and worked with the same Warning.
But when I install IC5.032 it does not works - Only message - "Bus error" and programm aborted.
And How can I fix this problem too?
I find several topics in this forum about:
"Warning: Cannot convert string "-adobe-helvetica-medium-r-normal--0-100-75-75-p-0-iso8859-1" to type FontStruct"
2. I reinstall RHLinux 7.3. Before installation I chek BIOS SETUP and set option SATA=Disabled (Default SATA=Auto). I have only IDE drives on my PC. After installation IC5.005 and IC5.032 works properly. Maybe BIOS option is the reason of my problem.
