Corvuscorax4
Newbie
i am making cnc plasma project. Controller crashes and looses steps when plasma cutter is working. I have few questions about grounding and shielding wires maybe somebody who had same experience can help me with advice how to solve my problem. Thank you for any help.
1.Do i need to ground stepper motors?
2.I use shielded wires and putting this wires in to metal corrugated tube. Question is do i need to ground wire shield and metal tube separate or i can connect them to one point. Also do i need to connect it inside metal encloser or outside?
3. Metal encloser and cnc plasma table frame are connected. Do i need to isolate metal encloser from plasma table frame?
4. What grounding system should i use?
