BoronCarbide
Newbie level 3
- Joined
- Jan 2, 2017
- Messages
- 4
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 52
No. Vb must be held at a constant 12 to 15 V offset (=VCC) above Vs, the diode is achieving this in combination with C2 in a regular half bridge configuration (low side drain connected to high side source). The doubts about the operation of your circuit have been raised because this connection is missing in the schematic.could I just use a transformer from mains and then rectify and supply to Vb as long as the transformer supply voltage is higher than the H-Bridge supply?
As already discussed, highside S1 will never turn on if S2 hasn't been operated before so that the bootstrap capacitor could be charged. In so far "later" doesn't work. It doesn't particularly matter how the IRS2186 low- and high-side drivers are arranged, having S1/S4 and S2/S3 driver combined can work, too, because both halves are electrically independent.As far as I am aware I am trying to create S1 and S4, which will turn on in unison. Later I will make S3 and S2 to turn on together, though in opposition to S1 and S4. This will provide full voltage swing across the load.
You need to supply external supply voltage to C2.
In order to open the high side Mosfet, there must be a voltage between G and S.
