ansu_s
Junior Member level 3
hi,
I try to design fully differential folded cascode amplifier, but have problems with CMFB stability (see attached circuit). There is too much phase shift in CMFB path (260 degrees!), but I not know where it is from!! And magnitude response of CMFB path is 80dB!! I think because of 40dB gain from cmfb amplifier, and then folded cascode output stage looks like additional gain stage to CMFB (another 40dB), is this right?
In CMFB path, I have pole at folded cascode output (two legs of folded cascode combined in parallel for CMFB path). Also, another pole at output of CMFB amplifier. And third pole at mirror node in CMFB amp. But I can't alter folded cascode pole, so can only adjust CMFB amplifier poles. But I must make CMFB output pole << differential GBW to reduce overall phase shift to make CMFB stable. But I need larger CMFB GBW than this, to respond to fast CM changes! What can I do here??
