abdj
Newbie level 1
cd4047 pspice
hi,
I want to know what is differene between pspice standard libraries and advanced analysis pspice libraries.
secondly,whenever any ic is used errors are generated not in netlist but when went for "check design
rules" . I 've been using CD4047 ic's, ULN2004A ,LM7805 ic's.whenever tried to simulate errors are generated regarding "templates".I 've ORCAD 9.2 edition.When same thing is done for op-amps and all and checked in properties of ic there exists something as template and implementation path and type which are filled,but for above listed ic's nohing is mentioned.So in every simulation errors are generated.
Even when the voltage or current markers are placed on pins of ic's which has been directly connected to source an error saying " no input data to pinxx" comes .Same is the case with output pins.It doesn't read at all and even if it reads it gives 0 reading
So if you could kindly help me about this.
hi,
