Problems simulating isolated voltage to frequency converter
MateusHG
Newbie
Newbie level 1
Hello everyone! I'm trying to simulate a circuit of an isolated voltage-to-frequency converter using the LM331 in LTspice, but I'm having issues with the "Time step too slow" error. I'm using a third-party LM331 model since it's not available in LTspice. How can I try to solve this problem? Attached are my file and the LM331 model I'm using.
  • V2F_converter.rar
The error message says "time step too SMALL"
If it is too small --> simply set it to a higher value.
Usually you are asked to input this value when you start the simulation (for the first time). You have to option to adjust simulation parameter at any time.
Klaus
No, that doesn't help. The error occurs if the model has unusual non-linearity or simulation circuit is unsuitable. Adjusting simulation parameters or selecting a different solver can help but not always.
I notice that simulation circuit is considerably different from data sheet application, I guess unintentionally. C2 = 1Meg (10e6) should be 1u (10e-6), also R5 value is far off. This may affect simulation convergence.
LaTeX Commands Quick-Menu:
