problems on gerber file in orcad16.0
pary
Newbie level 1
Newbie level 1
Respected sir/mam i am using orcad16.0 and i have problem in creating Gerber file. when i create Gerber file then all file what i required-top, Ast,smt,drd,gtdand .tap all file created but only .Gerber file for sst layer(silkscreen top) is not created sir please give me the solution foe the same
thank,s
go to option menu ---> post processing then spreadsheet will pop up as shown in attached image make sure enable for post processing option is selected for the *sst layer
And if you find that it is selected (Enable Post Processing is checked), make sure that what you want on the silkscreen is actually on the correct layer, Silk Screen Top or SST.
