[SOLVED] Problems of compiler Angstrom of DevKit8000
do interior
Member level 3
Member level 3
Brasil
I'm trying to compile the latest Angstrom for devkit8000 using the Makefile cd devkit8000 with minor changes based on the current makefile Angstrom, to better illustrate the sequence of commands to see, and your answers below:
export PATH=/home/Gabriel/embest/arm-2007q3/bin:/home/Gabriel/embest/tools:$PATH
cd /home/Gabriel/Git/angstrom-linux
make distclean
(ok)
make omap3_devkit8000_defconfig
(ok)
make uImage
CC lib/vsprintf.o
AR lib/lib.a
LD vmlinux.o
MODPOST vmlinux.o
GEN .version
CHK include/generated/compile.h
UPD include/generated/compile.h
CC init/version.o
LD init/built-in.o
(hundreds of lines later, with some:
/tmp/ccMtn9RH.s: Assembler messages:
/tmp/ccMtn9RH.s:201: rdhi, rdlo and rm must all be different
it appears)
LD .tmp_vmlinux1
arm-none-linux-gnueabi-ld: no machine record defined
make: ** [.tmp_vmlinux1] Erro 1
can someone help me?
once check your configuration
system type
OMAP34xx Based System=y
OMAP3430 support=y
then compile it will work
