Problems occur when IC50 installed on RHEL 3.0?
willyboy19
Full Member level 3
Full Member level 3
When tried to install IC50 on RHEL 3.0 (Kernel 2.4.21-4.EL), a bunch of errors show up:
Incorrectly built binary which accesses errno or h_errno directly. Needs to be fixed.
Can someone give some advise to solve this problem? Or RHEL 3.0 is not a friendly platform to support EDA tools?
Change your env setting as..
LD_ASSUME_KERNEL=2.4.1
that's it.
The error message actually happens when one tried to install IC50 during softload process:
Meanwhile, even after changed the .cshrc file to include
set LD_ASSUME_KERNEL = 2.4.1
The same error message still pops out when 'icms' is launched. Do you have any idea how to fix this problem?
