Problems Keil DS-5 and Linux for BeagleBoard
do interior
Member level 3
Member level 3
Brasil
For various reasons I felt compelled to try to enter the world of embedded Linux, and chose to start with BeagleBoard, which has not yet arrived, and the DS-5 of Keil:
https://www.keil.com/arm/ds5/
After installing the Windows version, decided to play a bit and installed the Git with it got the version of Linux for ARM OMAP:
git clone git: / / git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6.git linux-omap-2.6
When you try to mount the design, the following error:
**** Build of configuration Default for project Omap ****
make all
'uname' will fail, recognized as an internal command
or external, a program vel oper or a batch file.
-x was unexpected at this time.
Makefile: 535: C: / msysgit/msysgit/linux-omap-2.6/arch / / Makefile: No such file or directory
The system will fail can find the path specified.
process_begin: CreateProcess (NULL, gcc-print-file-name = include, ...) failed.
Makefile: 1173: *** multiple target patterns. Stop.
The first error refers to the following line of the makefile:
Subarch: = $ (shell uname-m | sed -es/i.86/i386 / -es/sun4u/sparc64 / \
-e s / arm .* / arm /-e s/sa110/arm / \
-e s/s390x/s390-and /-e s/parisc64/parisc / \
-e s / .* ppc / powerpc /-e s / mips .* / mips / \
-e s / sh [234] .* / sh /)
And I imagine many others derive from it, because he can not set the architecture, and not because, I imagine, that this statement was written for Linux and obviously does not work in Windows!
On the other hand, the DS-5 was made for Windows, and if he can not resolve these incompatibilities what good are they?
The makefile has to be changed?
The DS-5 has to be changed?
I have to be changed?
I'm delirious when I think of compiling a Linux kernel in windows?
Added after 3 minutes:
I found another makefile, it has a subarch: = arm,
Subarch: = arm
This solves one problem, but still several others:
**** Build of configuration Default for project OMAP ****
make all
In this line, 1173, has this:
$ (clean-dirs):
$ (Q) $ (MAKE) $ (clean) = $ (patsubst _clean_ %,%,$@)
Besides the problem of uname ...
Unfortunately, building the Linux kernel from within Windows is virtually impossible. You might be able to do so if you were working with a networked file system where the remote file system understood things like symlinks, but I've never successfully done that. DS-5 for Windows is much more about building applications on top of an existing Linux system and doesn't provide a tremendous amount of kernel debug support, but is a very nice tool for performing application build and debug.
---------- Post added at 08:49 ---------- Previous post was at 08:32 ----------
Apparently I was wrong. It seems some folks have used Cygwin as it seems to have some mechanism to replicate symlinks. I'm not sure why DS-5 doesn't provide this sort of mechanism, but I don't think that DS-5 includes all of the other standard Linux utilities required, such as 'tar' and 'ls'. Seems like a good question to bug ARM about.
See the Cygwin site at /ml/cygwin/2007-07/msg00856.html: Claudio Scordino - Re: Compiling a Linux kernel using Cygwin. I'm too new to the list to post URLs.
