Problems in thermal co-simulation in CST
chipvc
Newbie level 2
Newbie level 2
Hi all,
I did simulate simple microstrip model to monitor temperature of subtrate and stripline. This work is attached on my post. When I run thermal simulation, this has a following error.
This solver setup would lead to zero fields.Thermal solver stops.
Other microstrip/planar models I did well but only this work has the problem. Could you look at and let me know some points?
Thanks,
Dav-
  • ML-thermal.zip
From the file you attached, it is only a circuit model, you'd better simulate in the MWS.
Reactions: ATRY
    ATRY
