Problems and questions about LDV 5
benny16
Member level 1
Member level 1
Problem in LDV 5
The problems are:
1. If in the console window type ncverilog (single-step mode), that will compile the verilog files and pop up a window called "NClaunch interactive", what is this tool use for ?
2. If the files complied with ncvlog (mult-step mode), it needs to set two files for the library, how to set they ?
3. What is common file extension for Verilog design use ?
4. If have the library for LDV, how to set or use with the verilog files.
Thanks
Problem in LDV 5
I have the same problem as the second.
