STU_KNTU
Member level 1
hi guys.
i am using AD7655 4channel Analog to digital converter to convert TCD_Linear signal with Fpga.
but i have some problem.
fpga gives to ADC a Cnvst clock with 400 khz frequency and ADC gives to fpga a busy signal(time for converting signal.i am reading data from ADC in raising edge of busy.
but data pins (D0 to D15) are very invalid and their voltage is variable!!!some times 1v and some times 3.3v!
is there possibility that ADC got Burnt??i mean the eoc pin and busy pin are correct but not Data pins.
if ADC is good so is there possibility that i am reading data in bad times???
i am using it in 1 channel INA1.
