Problem working with H3LIS200DL (+-200g accelerometer)
Johnny101
Member level 1
Member level 1
Hi, I am using H3LIS200DL with RFduino (RFD22102 ) as microcontroller, I have used the schematic given in data sheet except I have connected CS pin to Vdd (for using I2C). Also, I am using Arduino H3LIS331Dl_demo code attached below.
The IC works fine for 5mins and then readings become constant. And when I use it again after 10 hours or so, it again works fine for 5mins only. This is happening from 3 days. I have also resoldered it and rechecked the capacitors.
I used 3 ICs. One worked fine but the same problem is happening with other 2.
Is this any soldering problem?
Am I missing any point?
Help would be appreciated.
H3LIS200Dl data sheet :
RFD22102 data sheet:
  • H3LIS331DL_Demo.txt
I don't think this is a hardware problem.
Therefore I'd check if the software is still running correctely.
..by using a scope to see the SCL and SDA. You should see the SDA line not to be constant, especially where the lower significant databits are transferred.
Klaus
