Munib
antenna problem
I want to transmitt some digital data wirelessely uptill a distance of about 10 meters.For this purpose I am using a mcu and RF modules from Linx technologies
TXM-418-LC and RXM-418-LC.These are receiver and transmitter modules respectively.i am using a planar antena by the same manufacturer called SPLATCH
Now poblem is when the transmitter and receivers are at a distance of around less than 3 feet i have reliable wireless link but as the distance increases
the quality of link becomes bad and bad(By quality i mean i start getting garbage data at higher distances)
Also when the distance is increased the performance of wireless link varies with the surroundings meaning as i will start moving between the link some times link becomes good and at the movement of some ponts it becomes bad.
I personally think that this problem is due to antenna
Any views why this is happening ? and if this is due to antenna problem some one Please guide me in making this antenna efficient or to design a new antenna by my self as i am very new to this RF field.
I some where read that a simple piece of wire can be used as antenna if we can calculate its required length if this is true help me in this regard
Please have a look at the datasheets of RF modules at the following links:
Plz note that i have not made PCB for using these RF modules i have mounted the modules and antenna on vero boards this may be a problem
