Problem with Waveform Parameters Setting in IC5141.
nkzz
Newbie level 5
Newbie level 5
hi,all.
When i use simulation by spectre,there's an error.
Error found by spectre during hierarchy flattening
V3:Waveform type must be specified if any waveform parameters are given.
Can anyone help me resolve the peoblem?
or give me some advices.
Thanks
The problem is that CDS_Netlisting_Mode is not set
to Analog. Exit the tool and set the environment
variable either in the xterm you are using by typing:
setenv CDS_Netlisting_Mode "Analog"
or enter this command in your .cshrc file and source it.
Then rerun the simulation after you recreat the netlist.
