Problem with VHDL entities in Quartus
davorin
Advanced Member level 3
Switzerland
Although I hate VHDL I have to use it from time to time (o;
And now I´m facing a strange problem with a altpll entity added in the top-level file.
Info: Found 2 design units, including 1 entities, in source file clkpll.vhd
	Info: Found design unit 1: CLKPLL-SYN
	Info: Found entity 1: CLKPLL
It correctly sees the altpll module but later on it says that it is un defined:
Error: VHDL error at usbtop.vhd(353): object "CLKPLL" is used but not declared
Error: Ignored construct USBTOP_arch at usbtop.vhd(35) because of previous errors
The top-level code looks like:
u_PLL : CLKPLL
port map (inclk0 => CLKINM,
   pllena => '1',
   areset => RST,
   c1 => GCLKM,
   c0 => CLKM,
   locked => LOCK);
I know it must be something stupid...and I hate those stupid VHDL which requires the right order of files imported into Quartus *arrgggghh.
VHDL entities in qu@rtus
Hello davorin,
Is it possible that there is a problem with the names of entity, architecture and component? Do they match together? Some times ago I had a mistake in my code and I think the errors where the same. Is the file “clkpll.vhd“ from you?
Did you checked the order of the imported files in Quartus? That’s a very stupid thing as you said.
Bye,
cube007
Re: VHDL entities in Quartus
Yes..clkpll.vhd is generated with the wizard using "altpll"...
Entity and architecture names match and component is "altpll".
Hmm..and doesn't even work when use a verilog pll module..
You said that your component has the name altpll, that means that you instantiation should look like “u_PLL : altpll” and not “u_PLL : CLKPLL”. It is working like this in my case.
Stupid (o;
Be careful using design files meant for Xilinx under Quartus (o;
Seems that Xilinx ISE doesn't require the "component" declaration for the PLL:
component clkpll
	PORT
		inclk0		: IN STD_LOGIC  := '0';
		areset		: IN STD_LOGIC  := '0';
		c0		: OUT STD_LOGIC ;
		c1		: OUT STD_LOGIC ;
		locked		: OUT STD_LOGIC
end component;
Now works (o;
Yes, that’s it. I created a project to check where the problem is. But you were faster than me (I had to help my mother with her PC :sm15: ). It is necessary to declare the component you would like to use in the architecture of usbtop.vhd.
component clkpll
		port (
			inclk0	: IN STD_LOGIC;
			areset	: IN STD_LOGIC;
			c0		: OUT STD_LOGIC;
			c1		: OUT STD_LOGIC;
	end component;
