Problem with using LCD_CHR in MIKROC
arash_micro
Member level 5
Member level 5
Hi
I have a prblem about using "LCD_CHR" command in MIKROC
This command ,print only CHAR vars.
For example
unsigned char ch;
ch=65
lcd_chr(2,1,ch);
But the LCD shows the "A" character
Is there simple way to print original var ?
If not,pleas some one explain me the "ADC_on_LCD" code from "mikroc"
c lcd_chr
what is this 'MICROC'?
is an c compiler? for which microcontroller?
inttostr mikroelectronika
You can finde it in
lcd_chr();
if you have print ascii code on LCD you can't do it in that way:
arash_micro said:
unsigned char ch;
ch=65
lcd_chr(2,1,ch);
first you must create string representation of ascii number, and pass that string to function lcd_out function
try this:
char buff[4];
unsigned char ch;
ch = 65;
ByteToStr(ch, buff); // fill buff with string representation of ch var
LCD_Out(2,1, buff);
mikroc longtostr
Thanks
but because of char,the maximum value is 255
How can i print 65783
lcd_chr mikroc
read microC manual, search 'Conversions Library',
conversion functions:
ByteToStr
ShortToStr
WordToStr
IntToStr
LongToStr
