Problem with using HSPICE 2007.03 after uninstalling 2006.09 version
pansoo
Junior Member level 2
Korea
Hi. all~
I used hspice 2006.09 correctly.
Few days ago, I found 2007.03, and I installed the version.
Then It was worked correctly. Thus I uninstalled 2006 version.
After that, the newer version became a donkey.
It shows me conclude message, But I can see any wave at Avanwaves.
The list file also shows me this message.
**warning** no dc outputs specified ... analysis omitted
Who knows the cause and solution?
1. Also I checked the .sp file is runned correctly in another PC.
2. I tried to reinstall 2006.09 version.
Best Regards.
I solved the problem by attatched below stagement.
.option post=1
I think 2006 version makes graphic file default without above option, but 2007 version needs the statement.
Thanks.
Re: HSPICE Problem
hi, out of curiousity, i compare the hspice 2007.03 and hspice 2004.03, using a same netlist, same tolerance settings, i didn't see any speed improvement, is it correct?
Re: HSPICE Problem
Use
.options accurate=1 NUMDGT=8 DELMAX=1n method=gear INGOLD=2 POST=1
Use Hspice 2007.9 to see speed improvement.
