Problem with using da to compile on redhat8
husteven
Junior Member level 2
problem of da on redhat8
We recently install s*y*n*o*p*s*y*s 2002.05-sp1 on redhat 8 .
there is no problem in dc_shell in redhat, but when we use da
the GUI come up as we expect, but when we use da to compile
it destroy the GUI and come with the notice below
start:
email: <your email address>
getfatal:
Release = '2002.05-SP1' Architecture = 'linux' Program = 'design_analyzer'
'162981504 162981750 1107463240 162951118 134573159 163863268 163863785 163516377 163516012 163962722 163890966 163892190 163892340 163893011 163892968 134545515 134538837'
end:
does any one can help us on it .
thank you!
what is the recommended os for 2002.05-sp1? Is it redhat 7.2?
It is very important to use the recommended os version for snps's products or otherwise you will get trouble in the GUI.
ntxp
any more segestion
Is there some patch of the system to help change solve the problem
without change my system back to 7.2?
Noway, just image, does synopsys have time to test all the linux releases on all the linux versions?
Synopsys Qualified Run-Time System Configuration
You must to see this document , before you setup synopsys software product .
one time i can run gui rightly, but another time i am failed in rh8.
so i think the tool have some wrong things in 8.0. maybe 7.2 is a right choose
The problem come from the qt lib support in redhat . You can try other windows manager like twm or fvwm to see if it can run .
