mhmmdrz92
Newbie level 2
I want to use carry look ahead and ripple carry adder components to write a vhdl code of a combinational adder. the inputs are 16 bits an the components are 4 bits, so i would use four of them. this is the code:
I recieve these similar errors from altera quartus:
Code VHDL - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 library ieee; use ieee.std_logic_1164.all; entity ETAII is port ( A : in std_logic_vector(15 downto 0); B : in std_logic_vector(15 downto 0); --cin : in std_logic; -- c_out : out std_logic; result : out std_logic_vector(15 downto 0) ); end ETAII; architecture rtl of ETAII is component carry_lookahead_adder is generic (g_WIDTH : natural := 4); port ( i_add1_cla : in std_logic_vector(g_WIDTH-1 downto 0); i_add2_cla : in std_logic_vector(g_WIDTH-1 downto 0); c_in_cla : in std_logic; -- c_result_cla : out std_logic ); end component carry_lookahead_adder; component ripple_carry_adder is generic (g_WIDTH : natural := 4); port ( i_add1_rca : in std_logic_vector(g_WIDTH-1 downto 0); i_add2_rca : in std_logic_vector(g_WIDTH-1 downto 0); c_in_rca : in std_logic:='-'; -- o_result : out std_logic_vector(g_WIDTH-1 downto 0) ); end component ripple_carry_adder; signal c1,c2,c3,c4 : std_logic; signal result1 : std_logic_vector(15 downto 0); begin cla1: carry_lookahead_adder generic map (g_WIDTH => 4) port map( i_add1_cla => A(3 downto 0), i_add2_cla => B(3 downto 0), c_in_cla => '0', c_result_cla => c1); rca1: ripple_carry_adder generic map (g_WIDTH => 4) port map( i_add1_rca => A(3 downto 0), i_add2_rca => B(3 downto 0), c_in_rca => '0', o_result => result1(3 downto 0)); cla2: carry_lookahead_adder generic map (g_WIDTH => 4) port map( i_add1_cla => A(7 downto 4), i_add2_cla => B(7 downto 4), c_in_cla => '0', c_result_cla => c2); rca2: ripple_carry_adder generic map (g_WIDTH => 4) port map( i_add1_cla => A(7 downto 4), i_add2_cla => B(7 downto 4), c_in_rca => c1, o_result => result1 (7 downto 4)); cla3: carry_lookahead_adder generic map (g_WIDTH => 4) port map( i_add1_rca => A(11 downto 8), i_add2_rca => B(11 downto 8), c_in_cla => '0', c_result_cla => c3); rca3: ripple_carry_adder generic map (g_WIDTH => 4) port map( i_add1_rca => A(11 downto 8), i_add2_rca => B(11 downto 8), c_in_rca => c2, o_result => result1 (11 downto 8)); cla4: carry_lookahead_adder generic map (g_WIDTH => 4) port map( i_add1_cla => A(15 downto 12), i_add2_cla => B(15 downto 12), c_in_cla => '0', c_result_cla => c4); rca4: ripple_carry_adder generic map (g_WIDTH => 4) port map( i_add1_rca => A(15 downto 12), i_add2_rca => B(15 downto 12), c_in_rca => c3, o_result => result1 (15 downto 12)); result <= result1; c_out <= c4; end rtl;
What should I do to solve this error?Error (10349): VHDL Association List error at ETAII.vhd(67): formal "i_add1_cla" does not exist
Error (10346): VHDL error at ETAII.vhd(66): formal port or parameter "i_add1_rca" must have actual or default value
Error (10784): HDL error at ETAII.vhd(32): see declaration for object "i_add1_rca"
Error (10346): VHDL error at ETAII.vhd(66): formal port or parameter "i_add2_rca" must have actual or default value
Error (10784): HDL error at ETAII.vhd(33): see declaration for object "i_add2_rca"
