Tohu
Full Member level 1
Hello to all,
Did somebody have experience with this chip? This is a USB 2.0 HUB the problem is that the chip work only like a USB 1.0 Hub, for some reason can't be switched to Full speed mode. The PCB is made according app note and USB 2.0 specification, I compare the circuit diagram with a working USB 2.0 hub with this chip, and I can' see any different, except one. The chip in this hub is 68 pin packages I am using a 48 pin. From each data pin thy have a 15 k to GND /I have too this resistor/ and 330 Ohm to pin on the side of data pin, marked as NC in data sheet.
Thanks in advance.
Thanks in advance.
