shyboy
Newbie level 6
Hi, all,
I recently built a switched-capacitor biquadratic building block for a high order lowpass filter...It was a lowpass notch biquad. I tested it out with Spectre. The result showed good dc gain and high frequecy gain as expected. However, the pole and zero locations deviated a lot from the expected values. And the transition was not as sharp as I thought. I tried to change some capacitor values to change the pole-zero location. It turned out that the dc gain changed a lot while the pole and zero lacations almost remained the same..Could anyone help me out of this problem? Thanks a lot!
shyboy
shyboy
