Problem with strange PIC behavior
mrcube_ns
Advanced Member level 1
Europe
Strange PIC behavior
Here some small test in Hi te ch Pi cc mcu is 16f628.
Here is code:
#include <pic.h>
//#include <pic1662x.h>
#define PORTBIT(adr, bit) ((unsigned)(&adr)*8+(bit))
//__CONFIG(CP1|CP0|CPD|FOSC2|FOSC0|WDTE);
static bit test @ PORTBIT(PORTB, 1);
unsigned int i;
void main (void)
TRISA = 0;
TRISB = 0;
PCON = 0xFF;
OPTION=0x40;
INTCON=0x90;
PORTA = 255;
PORTB = 255;
test=1;
while(1){
if(test == 0)
test = 1;
else
test = 0;
for(i=0;i<10000;i++){
}//for
}//while
}//main
Here is what I see on oscilloscope on test pin non simetrical square signal :
___| |________________________| |_________________________
Any ideas?
Is it something wrong with code, am I doing something wrong???
Mr.Cube
Re: Strange PIC behavior
It probably has to do with what instructions the compiler generates for the while loop, there probably is a GOTO involved (which takes 2 cycles).
If you need perfect timing better do it in MPASM and count the clock cycles for each instruction.
You can get strange things with the 628 if you don't disable the comparator functions when you are not using them!
ASM
movlw b'00000111' ; disable comparators
movwf CMCON
Hi mrcube_ns,
1)
Not HiTe user but it seems that you have the WDT enable.
2)
unsigned int i; // This is an 8 bit integer whose max val = 255
Then in the for loop, the conditional test is expecting something imposible.
for(i=0;i<10000;i++) // i < 10000 ??????
Hope this help you.
Regards,
Humber555
mrcube_ns,
as you do not use PORTA you can leave the comperators enabled without problems.
Your problem is that you have enabled the watchdog and do not reset it.
Put this:
asm("clrwdt");
in you for loop and you should get wat you want :)
best regards
Good to know that comparators can make trouble sometimes.
Humber555
integer is number between 0-65535 if it's defined as unsigned int value, so 10000 is very good int value (signed or unsigned no mater).
C-man tnx for answer, good point. But I deactivate WD option in programmer software (SW:ic prog, HW: propic2 programmer). Maybe software dont disable WD ?!!? All try to reset WD in while loop and see result.
Mr.Cube
Hi Humber555
unsigned int i;
These statments are vaild becuase
int i takes 2 bytes from -32768 to +32768
unsigned int i removes the signed and add them to the positive (i will value between 0 : 65535)
But
char i take 1 byte ( -127 to 128)
and so
unsigned char ( 0 -255)
SphinX
