Problem with slant region of OpAmps output
srivatsan
Full Member level 3
Full Member level 3
Help regarding OPAMP
hi,
i have a problem. when i simulated the differential amplifier, i think i got a weird output. i have attached both the files.
Output 2 file: the output corresponds when the inverting node is set to ground and DC sweep at non-Inverting input node.
v(19) is the output node from N-input transistors and v(27) is the output node from the P-input transistors. (Comparative study of diff-amp)
the problem is: why does there is a slant region in Output one file?
please reply if you have seen this before or remotely connected.
also how to avoid this problem, if it can be done?
Info: AMIS 0.5um process. Model from MOSIS.org.
regards,
srivatsan
Re: Help regarding OPAMP
Could you upload the circuit you are simulating?
Post your schematic please. Without that it is impossible to answer your question.
accidently, i wrote OPAMP on the heading.. well i had a problem with overall circuit (OPAMP). but i think i reduced it to diff amp problem. sorry for the confusion.
here i have posted the circuit schematic.
i would like to know ASAP.
About the schematic: the left side is a startup circuit, there are two diffamps, one is n-input and other is p-input transistors. i hope this helps.
regards,
srivatsan
There might be something wrong with the file. I tried to download twice but both times my computer hang.
The slant region "around the zero point" in your simulation results are the circuit's gain regions.
In the simulation results, you can find the n and p type differential pair common mode voltage range. The common mode voltage range of n type differential pair (yellow curve) is about -1.X to 2.3X and the p type one (the blue curve) is -2.3X to 1.2X.
When the circuits out of the dc common mode range, the input pair will go to the tri-region, the circuits' gain will decrease (the slant region "far away the zero point").
sorry to andy1. well when i downloaded it, i did not have a problem. no virus or any crap. i checked all these when i uploaded. so i am not sure what is your problem.
well, ICMR is given in that range... i think i interpret the result as: one of the transistors has gone into the triode region. hence the problem. (probably the "Iss" transistor).
if i am wrong, please clear that up. i would be thankful.
regards,
srivatsan
