sanazb
Newbie level 3
Hi all
I am a newbie in power electronic field. I have a flyback converter which I cannot get the desired result from the simulation in Pspice. I am not sure if the problem is from the transformer or the switching.
The circuit is supposed to convert a 3.7 VDC from a Battery to 200 VDC.
I am using the following parameters for the circuit:
Cin=4.2uF
Chv=0.22uF
The Transformer Parameters would be as followed:
L1=6.2uH
R1=1 Ohm
L2=300uH
R2=42.7Ohm (R1 and R2 are supposed to be the winding resistance)
right now I get 90 VDC regardless of whatever change I make I my circuit (changing the turn ratio, changing the input voltage)
I have tried to simulate it in MatLab simulink and I get the same result.
Could you please help me figure out where the problem is and why I cannot get the 200VDC output?
Cin=4.2uF
Chv=0.22uF
L1=6.2uH
R1=1 Ohm
L2=300uH
