Problem with SIM 300 - +CMS error: 517
Krishna Patil
Member level 1
Member level 1
Shimoga, Karnataka, India
I bought SIM 300 V 7.03 , connected to PC via RS -232 , using hyperterminal , AT commands like AT,ATI are working but error +CMS error : 517 comes when trying t send SMS and also after powering
+CPIN: NOT INSERTED
+CFUN: 1
I googled it , that means " SIM not inserted " . But i inserted SIM in proper position ,
Voltage between Pin 1 and pin 5 of sim connectors is zero. What might be wrong ? or module fault ?
Re: Problem with SIM 300
There maybe some problem with the SIM HOLDER slot connections.
Check its connections.
If any problem, try soldering it.
    V
