Problem with setting Kernel for RTC with SAM9260
impet14
Junior Member level 3
Thailand
Any can help me to use RTC with SAM9260?
Thanks in advance.
Re: Please help with RTC
What type of help?
Amr
for internal RTC ,how to set kernel?
What Kernel? Are you talking about linux Kernel?
Amr
yes,linux kernel.
Is its driver enabled in the kernel?
Amr
I've enabled RTC
So, Your program is in programming RTC. You need an example program right?
Amr
I set the kernel configuration as
CONFIG_RTC_LIB=y
CONFIG_RTC_CLASS=y
CONFIG_RTC_HCTOSYS=y
CONFIG_RTC_HCTOSYS_DEVICE="rtc0"
CONFIG_RTC_DEBUG=y
# RTC interfaces
CONFIG_RTC_INTF_SYSFS=y
CONFIG_RTC_INTF_PROC=y
CONFIG_RTC_INTF_DEV=y
# CONFIG_RTC_INTF_DEV_UIE_EMUL is not set
CONFIG_RTC_DRV_TEST=y
# I2C RTC drivers
# CONFIG_RTC_DRV_DS1307 is not set
# CONFIG_RTC_DRV_DS1374 is not set
# CONFIG_RTC_DRV_DS1672 is not set
# CONFIG_RTC_DRV_MAX6900 is not set
# CONFIG_RTC_DRV_RS5C372 is not set
# CONFIG_RTC_DRV_ISL1208 is not set
# CONFIG_RTC_DRV_X1205 is not set
# CONFIG_RTC_DRV_PCF8563 is not set
# CONFIG_RTC_DRV_PCF8583 is not set
# CONFIG_RTC_DRV_M41T80 is not set
# CONFIG_RTC_DRV_S35390A is not set
# CONFIG_RTC_DRV_FM3130 is not set
# CONFIG_RTC_DRV_RX8581 is not set
# CONFIG_RTC_DRV_RX8025 is not set
# SPI RTC drivers
# Platform RTC drivers
# CONFIG_RTC_DRV_CMOS is not set
# CONFIG_RTC_DRV_DS1286 is not set
# CONFIG_RTC_DRV_DS1511 is not set
# CONFIG_RTC_DRV_DS1553 is not set
# CONFIG_RTC_DRV_DS1742 is not set
# CONFIG_RTC_DRV_STK17TA8 is not set
# CONFIG_RTC_DRV_M48T86 is not set
# CONFIG_RTC_DRV_M48T35 is not set
# CONFIG_RTC_DRV_M48T59 is not set
# CONFIG_RTC_DRV_BQ4802 is not set
# CONFIG_RTC_DRV_V3020 is not set
# on-CPU RTC drivers
CONFIG_RTC_DRV_AT91SAM9=y
CONFIG_RTC_DRV_AT91SAM9_RTT=0
CONFIG_RTC_DRV_AT91SAM9_GPBR=0
CONFIG_DMADEVICES=y
booting show that
rtc-at91sam9 at91_rtt.0: rtc core: registered at91_rtt as rtc0
IRQ 1/rtc0: IRQF_DISABLED is not guaranteed on shared IRQs
rtc-at91sam9 at91_rtt.0: rtc0: SET TIME!
rtc-test rtc-test.0: rtc core: registered test as rtc1
rtc-test rtc-test.1: rtc core: registered test as rtc2
i2c /dev entries driver
i2c-gpio i2c-gpio: using pins 55 (SDA) and 56 (SCL)
Registered led device: led_stat
Registered led device: led_pwr
TCP cubic registered
Initializing XFRM netlink socket
NET: Registered protocol family 17
NET: Registered protocol family 15
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
rtc-at91sam9 at91_rtt.0: hctosys: unable to read the hardware clock
Added after 5 minutes:
and I've got
sam9-l9260:~# hwclock --date "28 JUN 2010 17:28"
RTC_RD_TIME: Invalid or incomplete multibyte or wide character
ioctl() to /dev/rtc to read the time failed.
