Problem with S parameter in planar antenna design done in HFSS 9.2
pbuarque
Newbie level 1
Newbie level 1
I'm starting to use HFSS so I must be doing something wrong. As you may see in my file I am trying to get a planar antenna to work. However, S parameter is (in absolute value) too low, I was expecting something greater than -20dB. Please help me. The hfss extention has been changed to hfs
Thanks
Pedro
Re: HFSS 9.2 S Parameter
Dear Pedro,
what is your design frequency of the patch antenna. what is your reference of the design there is a resonance at about 4 GHz.
there are notes about the setting like the Rad is not lambda/4 distance from the antenna surface, and the ground slug is not an infinite. but non of these provide a reason why your is off.
note the substrate is so small in thickness why??
