Problem with running a TUSB3210 programmer
egemini
Full Member level 2
Full Member level 2
GOC
tusb3210 source code
hello ,have any body tried with tusb3210.
I constructed a USB programmer based on elektor article (june2004)
its not working properly.
Please help?
thanks
egemini
Re: TUSB3210
Hey
Is there an serial eeprom or does the code come from the usb port every time ?
if it comes from the usb port, you need to install the right driver, so it will upload the sorcefile everytime it connects, and then it releases the usb port to the source code...
there is plenty of information on that topic at TI.COM
If you are using the eeprom then make sure the header is correct
regards
Repzak
Re: TUSB3210
Hi
I also built this programmer, and it is working great!!!
Verry fast, and without problems.
I sent a note to Elektor, because they put a wrong IC in the partlist.
Take a look at the schema, there the correct IC is listed.
Instead of the 74LS04 you must take an 74LS07 !!!
It took me one day to find out, but since then the programmer works perfect.
Hope I could help you.
Cheers
Rubi
