Problem with recompiling Xilinx Libraries in ModelSim
BasePointer
Full Member level 2
Full Member level 2
TURKEY
modelsim, cd $, modelsim.ini
I have just downloaded ModelSim 5.8d. I gave an error message "Permission denied" when I tried command below. How can I prevent this ?
ModelSim> compxlib -s mti_se -f all -l all -o .
# Release 6.2i - compxlib
# XILINX = 'C:\_Elkn\Xilinx'
# SIMULATOR = MODELSIM SE/EE
# Source Tools => [using PATH env]
# Initializing Logical Mapping ( => 'C:\_Elkn\FPGAdv62PS\Modeltech\win32' )
# output directory set to 'c:\_elkn\fpgadv62ps\modeltech\examples'
# checking dependencies...
# Using MODELSIM ( => C:\_Elkn\FPGAdv62PS\Modeltech\win32/../modelsim.ini )
# ==> STARTING COMPILATION (Xilinx VERILOG Libraries)
# Warning: Copied C:\_Elkn\FPGAdv62PS\Modeltech\win32/../modelsim.ini to modelsim.ini.
# Updated modelsim.ini.
# MODELSIM set to C:\_Elkn\FPGAdv62PS\Modeltech\win32/../modelsim.ini.
# The MODELSIM environment variable is used by all ModelSim products
# to find the modelsim.ini file, so this local copy will not be used.
# Error: Could not write to C:\_Elkn\FPGAdv62PS\Modeltech\win32/../modelsim.ini: Permission denied
Thanks
modelsim xilinx libraries
Are you logged in as Administrator? If not, are the permissions on that directory *and* the root of C: ok for your login?. If there is an existing modelsim.ini in that directory, is it Read Only?
I take it you are running compxlib from a console where you have CD'd to the root Xilinx directory?. Oh - also check if there is an existing compxlib.log which is Read Only.
Git
Yes, common problem. Change your modelsim.ini from read-only to writeable. I also keep a backup copy, just in case.
Yes I changed the modelsim.ini to writeable, it works now.
Thnks for your responses.
