Lebelin
Newbie level 6
I make a data logger to have information on the electric situation on an amateur television relay.The display use an OSD circuit and i wish to use a DS2450 to obtain infos on the batteries charge current.Other 1wire circuits are already used without trouble.(time,temperature)
I encountered a problem in reading the voltage informations with DS2450.
When i select the port to be used with the "select mask" the last one is alway wrong. I explain, i select channels C and D to read voltage, the value D is perfect but the value C is wrong (about 5% more).If i select B,C and D then C and D are correct but B has the same error problem. I tryed in changing the"read out" control without résults.
Somebody have an idea how to resolve the matter as i need 2 channels for reading Volts and Amp and the 2 others have to be used as alarm to switch off the relay if current is below the thresholds.??
Thanks for the help
Thanks for the help
