Problem with reading CDS IC5 manual
pigkiller
Member level 4
Member level 4
Hangzhou
cdsdoc problem
hi,all
when the installation end and i wanna read cds ic5 manual,i choose one from the cdsdoc,when i double click the material,netscape installation directory was asked.i use RH 8.0,i can't find netscape in it.i download it from internet,but the installation was failed .could the mozzila installation directory will be ok?
thank you!
download the version for linux, and add the netscape path into $PATH,
All will OK.
cdsdoc problem
You can run the mozzila first, and then run the cdsdoc in the terminal.
Good luck!
Re: cdsdoc problem
I use mozilla too. But do you know how can I configure the cdsdoc to run mozilla at default as it was netscape?
Re: cdsdoc problem
you can create a symbolic link of mozilla as netscape and it works
ln -s [path of mozilla] netscape
have some kind of problem with java not installed on mozzila can some one help for that?
