You'd better thougt about this before you bought it.
You need to ensure that the wiring is in same order as with the AtMega8 DIP case.
Maybe you need an additional adapter for this, because you can't be sure that every random QFP32 socket is identical.
Klaus
Do the pins at the bottom side of the QFP adapter fit into the ZIF socket of the programmer? Usually pin1 to pin1.
(From the pictures it doesn't seem so).
Klaus
A compatible Atmega8 QFP32 to DIP28 adapter would be expected to have 28 pins.
The shown adapter has 32 pins, I guess it has a 1:1 pin wiring (you may have already checked). In this case, the adapter can be only used with a specific programmer if the programmer is prepared for performing the required pin mapping. You should check the documentation.
I found that newer TL866 II supports ATmega QFP32 programming but TL866 doesn't. It would require a special wired adapter according to DIP28 pin mapping. See the information for TL866 II below.
what´s the programming voltage and the programming SCK frequency?
What´s your fuse setup?
Please confirm: The programmer usues serial programming mode?
Klaus
Sadly you give just half of the information I asked for.My fuse setup is Low byte - 0x83 and High byte - 0xC9.
assuming the two devices are identical except for packaging, the pins for one should match the pins for the other for programming purposes.
And the given infirmations are different as shown in the third picture of post#10, where it says Lfuse, Hfuse= 0x61, 0xDF.
How can we know what is correct?
Klaus
