Problem with PSpice OrCAD
adderek
Newbie level 3
Newbie level 3
no pspicetemplate for u1a, ignoring
In 'Orcad Capture 9.2':
I've placed an amplifier
AD8072
connected to an simple circuit. I'm running simulation and...
WARNING [NET0093] No PSpiceTemplate for U1A, ignoring
What is this and what to do to make this error gone in order to run this simulation and view it's results ? thanks in advance
pspice problems
Hi
This is not a 100% solution, but when I had these problems it has been related to none or wrong spice model.
Do you have the model AD8072 in Amplifier.olb?
If not DL the macro model here:
ttt.analog.com/Analog_Root/static/techSupport/designTools/spiceModels/license/spice_general.html?cir=ad8072jn.cir
Post again if this post is of no useand I try to help. I can also see if I can find a eradymade model for you.
ttt=3xw
Cl
problem in pspice
As You can see I'm a newbie. I do have 'AD8072' in apmlifier.olb, however
I've downloaded this .cir file and now I don't know what to do with it.
Some background about me :
I have to make an project in this semester so I have to learn OrCAD...
I know that I could use only amplifiers, resistors and transistors (cause only those I can get from local shop and I'll have to make a real working circuit after creating virtual simulation in OrCAD).
I'm trying to do anything with amplifier. I know what amplifier should do since last month :(
And now I don't know where can I put this .cir file into project....
If you can help me - please, do so
.cir to .olb
Hi
Offcourse we try to help you out, these error messages can sometimes be kind off frustrating. What is it you have to build, tell us a bit more and it is easier to give advice(s). As you already have the model there is no need to have the cir. Tell me a bit more and I
The error you got is connected to wrong or no spice model, I think something is wrong there. If you need to make a simulation within you project you cannot choose a part from INSTALL DIR\Capture\Library you must get one here:INSTALL DIR\Capture\Library\PSpice perhaps thats the problem.
Here are a faq: ttt.orcadpcb.com/pspice/faqs.asp?bc=F
Good luck
Cl
problems instaling orcad
Could You tell me how I can use parts from
INSTALL DIR\Capture\Library ?
In other words - where can I get models with simulation info ?
By the way - You helped me and now I know why You are a Super Moderator :)
installing orcad problems
Hi
The model is here:
Some Path \Capture\Library\Pspice called anlg_dev
Use that one and I hope it will work for you. If not just post.
Cl
