problem with proteus
sead
Newbie level 5
Newbie level 5
how to set a center tap transfomer;primary is 230v to secondary 9v using proteus?
didn't get it.where do you create/edit the value at?
From the generator mode select two SINE wave signals as a input.
Put RMS voltage 115 and -115 with 50Hz frequency.
This create your 230V AC,50Hz sign wave input signal.
Then edit properties of the transformer component.
Set coupling factor as 0.0554.
to get exact 9V for center tap transformer.
Check with oscilloscope and AC volt meter.
Reactions: sead
    sead
thanks.can i use altenator/ac source.is it same?
