hansika
Member level 2
hi all,
i am dumping hex file in dspic30f6014A using parallel port(TAIT ckt) and the software i am using is winpic 800(propic2) i am able to dump the code successfully but here the problem is i need to remove the reset circuit every time to dump the code i.e when i am connecting the controller and programmer with reset(RC circuit) circuit present controller is not identifying however if i remove the reset circuit the programmer is working fine . why this is happening can't we program a controller in presence of Reset circuit.
