Problem with programming ATmega32
cai2
Member level 2
Member level 2
hi guys!...we have a problem regarding with the programmer of atmega32... Every time we try to load it with a program an icon appears that says, a device is missing,what could be the possible reason why it is not working?
Re: atmega32
It says your connection to the device is not proper, I hope it is RS232, then look for loose cable, wrong cable etc. Give some more details about your connections to the device, a block diagram or even a detailed cicuit drawing. You should have posted this message under Microcontroller section for better respose.
Regards,
Laktronics
