sonnyasu
Newbie level 5
Hi, I 'm trying to make my pll work under certain input frequency range (from 2Mhz to 16Mhz with 4x 6x and 8x). I did stability analysis and plot the bode. It seems the phase margin is good enough (60 degrees), however, when I simulated at 16Mhz input with 4x multiplier, the system oscillates. At lower frequency everything is fine. Anyone knows why?
