Problem with PIC18F4550 with the LM35
susuying
hey,
i currently use the LM35 sensor to detect the temperature changes. the microcontroller that i use is PIC18F4550, and the output detector is just the LED.
i using 5 LED as the output.
Below is my coding, is there any problem?
void main(void)
TRISB=0B00000000
#define LED1 PortBbits.RB0
if (t=25)
LEC1=1; //will make port B0 high
else
LED1=0; //will make port B0 low
#define LED2 PortBbits.RB1
if(t=26)
LEC2=1; //will make port B1 high
else
LED2=0; //will make port B1 low
#define LED3 PortBbits.RB2
if(t=27)
LED3=1; //will make port B2 high
else
LED3=0; //will make port B2 low
#define LED4 PortBbits.RB3
if(t=28)
LED4=1; //will make port B3 high
else
LED4=0; //will make port B3 low
Off the cuff, here are my primary concerns:
1. Where do you read in the ADC value into your program? (I don't see anything being assigned to "t").
2. Where is your code to process the raw ADC value (0 to 65535 --> -10C to 50C, or whatever the scaling is...)
3. Your program will run exactly once, so the LED will blip once, then the program ends. You should wrap the entire program in an endless while loop, like so:
while(1)
<your code goes here>
} //loop repeats until you reset the PIC, or disconnect power
Agreement with "enjunear", with one exception ,I have my doubt that even LEDs will blink once, just have a look how you have defined LEDs blinking:
else
I dont see PORTB0 going high/low unless both are LED1.
this is the complete source code. But it still got error, i do not understand where is the error. Can is use if...else if in c compliler? can it read it?
LM35 Temperature Sensor INTERFACING TEST PROGRAM
Simple Program to connect with LM temperature sensor using the
internal ADC of PIC MCU.
The program displays the current environment temperature on
LCD Module.
MCU: PIC18FXXXX Series from Microchip.
Compiler: HI-TECH C Compiler for PIC18 MCUs (Embedded C Compilers and Tools for Software Development: HI-TECH Software)
#include <p18f4550.h>
#include <math.h>
#define LED5 PortBbits.RB4
//Simple Delay Routine
void Wait(unsigned int delay)
for(;delay;delay--)
__delay_us(100);
//Function to Initialise the ADC Module
void ADCInit()
//We use default value for +/- Vref
//VCFG0=0,VCFG1=0
//That means +Vref = Vdd (5v) and -Vref=GEN
//Port Configuration
//We also use default value here too
//All ANx channels are Analog
ADCON2
*ADC Result Right Justified.
*Acquisition Time = 2TAD
*Conversion Clock = 32 Tosc
ADCON2=0b10001010;
//Function to Read given ADC channel (0-13)
unsigned int ADCRead(unsigned char ch)
if(ch>13) return 0; //Invalid Channel
ADCON0=0x00;
ADCON0=(ch<<2); //Select ADC Channel
ADON=1; //switch on the adc module
GODONE=1;//Start conversion
while(GODONE); //wait for the conversion to finish
ADON=0; //switch off adc
return ADRES;
void main()
//Initialize the ADC Module
ADCInit();
while(1)
unsigned int val; //ADC Value
unsigned int t; //Temperature
val=ADCRead(0); //Read Channel 0
Wait(1000);
TRISB=0B00000000 [ this code show an error]
else if (t=25)
else if
else if(t=26)
else if
else if(t=27)
else if
else if(t=28)
else if
else if(t=29)
LED5=1; //will make port B4 high
else if
LED5=0; //will make port B4 low
this is the error comment:
Debug build of project `C:\Users\Odin\Desktop\babe\coding\temperature sensor2.mcp' started.
Language tool versions: mpasmwin.exe v5.35, mplink.exe v4.35, mcc18.exe v3.35
Preprocessor symbol `__DEBUG' is defined.
Mon Mar 14 12:02:23 2011
Make: The target "C:\Users\Odin\Desktop\babe\coding\temperature_sensor2.o" is out of date.
Executing: "C:\MCC18\bin\mcc18.exe" -p=18F4550 /i"C:\MCC18\h" "temperature_sensor2.c" -fo="temperature_sensor2.o" -D__DEBUG -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
C:\Users\Odin\Desktop\babe\coding\temperature_sensor2.c:109:Error: syntax error
Halting build on first failure as requested.
Debug build of project `C:\Users\Odin\Desktop\babe\coding\temperature sensor2.mcp' failed.
Mon Mar 14 12:02:25 2011
BUILD FAILED
---------- Post added at 05:05 ---------- Previous post was at 05:03 ----------
LCD Module.
#include <math.h>
for(;delay;delay--)
__delay_us(100);
void ADCInit()
//VCFG0=0,VCFG1=0
ADCON2
ADCON2=0b10001010;
ADCON0=0x00;
return ADRES;
void main()
ADCInit();
while(1)
Wait(1000);
else if (t=25)
LED1=1; //will make port B0 high
else if
else if(t=26)
LED2=1; //will make port B1 high
else if
else if(t=27)
else if
else if(t=28)
else if
else if(t=29)
else if
//the error is it because i din not define the LED??//
Make: The target "C:\Users\Odin\Desktop\babe\coding\temperature_sen sor2.o" is out of date.
C:\Users\Odin\Desktop\babe\coding\temperature_sens or2.c:109:Error: syntax error
BUILD FAILED
Hi susuying,
LM35 is a temperature proportional voltage out sensor, (get the datasheet).
You have to read Voltage of Vout of LM35 and convert it to temperature. (+ 10.0 mV/°C scale factor). First you have implement that in your code. Then assign temperature to t, after that above code will work.
google the topic, link to same kind projects are;
Interfacing LM35 Temperature Sensor with PIC Microcontroller. | eXtreme Electronics
Welcome to Cytron Technologies - Robot . Head to Toe : PIC Training Malaysia, PIC Microcontroller
Thanks
There are two ways your problem could be resolved:
First someone else does it for you.
Second you do it yourself.
If I were in your position I'd prefer doing it myself. Firstly in the main window of MPLAB, there is an option where it is saying "DEBUG" change it to release.
Your one compile time error is gone.
Open up Microchip C18, manual and look for error 109, its a syntax error find where is the error, rectify it and hopefully your code will compile.
There is a working code for LM35, by Simon Inns.
Search Google for his name, go to his website something about waiting for friday, there is a 8x16 clock and temp sensor. Thats the one you should have a look at, it has complete source codes.
Hi susuying,
hey,
i'm new in this so i don really understand what is mean by u?
Cant we just use the LM35 to detect the temperature changes directly? Do we need to set the value 1st in the coding part? if i assign a temperature t to the coding then will it influence the output from LM35?
sorry if i ask silly question, cause i really confusing.
Thanks
---------- Post added at 03:00 ---------- Previous post was at 01:30 ----------
this is my current coding. But i still get some error. Can someone tell me how to solve the error?
How to define the adc part?
The program displays the current environment temperature on LED
#include <math.h>
#include <adc.h>
#include <stdlib.h>
//*LEDs defination
#define LED1_PORT PORTB
#define LED2_PORT PORTB
#define LED3_PORT PORTB
#define LED4_PORT PORTB
#define LED5_PORT PORTB
//Function to Initialize the ADC Module
void initADC(void)
//VCFG0=0,VCFG1=0
ADCON2
ADCON2=0b10001010;
ADCON0=0;
GO_DONE=1;//Start conversion
while(GO_DONE); //wait for the conversion to finish
return ADRES;
void main()
ADCInit();
while(1)
Wait(1000);
return t;
TRISB=0b0000000;//All port B is set as output
if (t=250)
LED1_PORT=1; //LED1 only activated only for temperature equal to 25'c
LED2_PORT=0; //LED2 will not activated
LED3_PORT=0; //LED3 will not activated
LED4_PORT=0; //LED4 will not activated
LED5_PORT=0; //LED5 will not activated
else if (t=260)
LED1_PORT=0; //LED1 will not activated
LED2_PORT=1; //LED2 only activated only for temperature equal to 26'c
else if (t=270)
LED3_PORT=1; //LED3 only activated only for temperature equal to 27'c
else if(t=280)
LED4_PORT=1; //LED4 only activated only for temperature equal to 28'c
else if(t=290)
LED5_PORT=1; //LED5 only activated only for temperature equal to 29'c
Here is the error:
Tue Mar 15 09:56:27 2011
Executing: "C:\MCC18\bin\mcc18.exe" -p=18F4550 "temperature_sensor2.c" -fo="temperature_sensor2.o" -D__DEBUG -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
C:\Users\Odin\Desktop\babe\coding\temperature_sensor2.c:76:Error [1105] symbol 'ADON' has not been defined
C:\Users\Odin\Desktop\babe\coding\temperature_sensor2.c:76:Error [1101] lvalue required
C:\Users\Odin\Desktop\babe\coding\temperature_sensor2.c:78:Error [1105] symbol 'GO_DONE' has not been defined
C:\Users\Odin\Desktop\babe\coding\temperature_sensor2.c:78:Error [1101] lvalue required
C:\Users\Odin\Desktop\babe\coding\temperature_sensor2.c:80:Error [1105] symbol 'GO_DONE' has not been defined
C:\Users\Odin\Desktop\babe\coding\temperature_sensor2.c:82:Error [1105] symbol 'ADON' has not been defined
C:\Users\Odin\Desktop\babe\coding\temperature_sensor2.c:82:Error [1101] lvalue required
C:\Users\Odin\Desktop\babe\coding\temperature_sensor2.c:91:Warning [2058] call of function without prototype
C:\Users\Odin\Desktop\babe\coding\temperature_sensor2.c:104:Warning [2058] call of function without prototype
C:\Users\Odin\Desktop\babe\coding\temperature_sensor2.c:105:Warning [2052] unexpected return value
Tue Mar 15 09:56:29 2011
BUILD FAILED
The solution to your problem lies within the error report and code that you have posted :
C:\Users\Odin\Desktop\babe\coding\temperature_sens or2.c:76:Error [1105] symbol '[B]ADON[/B]' has not been defined
C:\Users\Odin\Desktop\babe\coding\temperature_sens or2.c:76:Error [1101] [B]lvalue required[/B]
C:\Users\Odin\Desktop\babe\coding\temperature_sens or2.c:78:Error [1105] symbol [B]'GO_DONE[/B]' has not been defined
C:\Users\Odin\Desktop\babe\coding\temperature_sens or2.c:78:Error [1101] [B]lvalue[/B] required
C:\Users\Odin\Desktop\babe\coding\temperature_sens or2.c:80:Error [1105] symbol '[B]GO_DONE[/B]' has not been defined
C:\Users\Odin\Desktop\babe\coding\temperature_sens or2.c:82:Error [1105] symbol '[B]ADON[/B]' has not been defined
C:\Users\Odin\Desktop\babe\coding\temperature_sens or2.c:82:Error [1101] [B]lvalue[/B] required
C:\Users\Odin\Desktop\babe\coding\temperature_sens or2.c:91:Warning [2058] [B]call of function without prototype[/B]
C:\Users\Odin\Desktop\babe\coding\temperature_sens or2.c:104:Warning [2058] [B]call of function without prototype[/B]
C:\Users\Odin\Desktop\babe\coding\temperature_sens or2.c:105:Warning [2052] unexpected return value
I have made the relevant areas "BOLD" just have a look at them, apparently ADON should be ADCON.
You need to define GO_Done.
You still have the debug option selected, I thought you would have changed it to release by now.
Hi susuying,
Codes in above posted links are in HI-TECH C, so you should use that compiler. If you use C18, study the steps in those codes and write your own code using C18.
See "A/D CONVERTER FUNCTIONS" section in "MPLAB C18 C compiler libraries.pdf" file (in "doc" folder of C18 installation directory)
#include "p18f4550.h"
#include "adc.h"
#include "delays.h"
#pragma config WDT = OFF
#define LEDPin1 LATAbits.LATA3 //Define LEDPin as PORT A Pin 1
#define LEDTris1 TRISAbits.TRISA3 //Define LEDTris as TRISA Pin 1
#define LEDPin2 LATAbits.LATA5 //Define LEDPin as PORT A Pin 2
#define LEDTris2 TRISAbits.TRISA5 //Define LEDTris as TRISA Pin 2
#define LEDPin3 LATEbits.LATE0 //Define LEDPin as PORT E Pin 3
#define LEDTris3 TRISEbits.TRISE0 //Define LEDTris as TRISE Pin 3
#define LEDPin4 LATEbits.LATE1 //Define LEDPin as PORT E Pin 4
#define LEDTris4 TRISEbits.TRISE1 //Define LEDTris as TRISE Pin 4
#define LEDPin5 LATEbits.LATE2 //Define LEDPin as PORT E Pin 5
#define LEDTris5 TRISEbits.TRISE2 //Define LEDTris as TRISE Pin 5
void main(void)
    double temperature=0.25;
    /**************** CONFIGURATION THE OSCILLATOR FOR PIC *********************/
    //OSCCONbits.SCS1=1;                // Use of the internal oscillator at 8Mhz frequency
    //OSCCONbits.SCS0=1;                // Utilisation for the internal osciallator in PIC
    //OSCCONbits.IRCF0=1;                //
    //OSCCONbits.IRCF1=1;                // Frequency oscillator at 8Mhz
    //OSCCONbits.IRCF2=1;                //
    //TRISBbits.TRISB0=1;                // Configure  RB0 as input for the Temperature sensor
    //TRISBbits.TRISB1=0;                // Configure  RB1 as output for the LED.
    //TRISBbits.TRISB2=0;                // Configure  RB2 as output for the LED.
    //TRISBbits.TRISB3=0;                // Configure  RB3 as output for the LED.
    //TRISBbits.TRISB4=0;                // Configure  RB4 as output for the LED.
    //TRISBbits.TRISB5=0;                // Configure  RB5 as output for the LED.
    OpenADC(ADC_FOSC_32 & ADC_RIGHT_JUST & ADC_4_TAD,
            ADC_CH0 & ADC_INT_OFF & ADC_REF_VDD_VSS,
            ADC_2ANA);    // Open the ADC in the Channel 0 (RA0; AN0,RA1;RN1 as input pin) with +5V reference level (=Vdd) and 0V as Vss. AN0-AN1 as analog while AN3-AN15 as digital pin
    while(1)
    //    Delay10TCYx( 5 );
        ConvertADC();
        while(BusyADC());
        temperature=ReadADC();
        if (temperature=0.24)
    LEDTris1 = 0;//Set LED Pin data direction to OUTPUT
    LEDPin1 = 1;//Set LED Pin
    while(1)
        LEDPin1 = ~LEDPin1;//Toggle LED Pin
        Delay10KTCYx(25);//Delay 250K cycles (1 second at 1MHz since each instruction takes 4 cycles)
        else if (temperature=0.25)
    LEDTris2 = 0;//Set LED Pin data direction to OUTPUT
    LEDPin2 = 1;//Set LED Pin
    while(1)
        LEDPin2 = ~LEDPin2;//Toggle LED Pin
        else if (temperature=0.26)
    LEDTris3 = 0;//Set LED Pin data direction to OUTPUT
    LEDPin3 = 1;//Set LED Pin
    while(1)
        LEDPin3 = ~LEDPin3;//Toggle LED Pin
        else if (temperature=0.27)
    LEDTris4 = 0;//Set LED Pin data direction to OUTPUT
    LEDPin4 = 1;//Set LED Pin
    while(1)
        LEDPin4 = ~LEDPin4;//Toggle LED Pin
        else if (temperature=0.28)
    LEDTris5 = 0;//Set LED Pin data direction to OUTPUT
    LEDPin5 = 1;//Set LED Pin
    while(1)
        LEDPin5 = ~LEDPin5;//Toggle LED Pin
    CloseADC();    // In reality, the ADC is never closed due to the while(1)...
Hey, i get my code modified. It can successfully run by C18. But when i test with my hardware, it keep blink 1 of the LED with the wrong input. Example: when i set the temperature is 0.25 and it should be running the 2nd LED, but end up it just run the 3rd LED.
please help!!
I think you have a range/resolution problem for your IF statements (too accurate, what if temperature is 0.250001?
Instead of using a finite value for each level comparison, use a range.
Something like...
if (temp <= 0.24)
Blink LED1
else if ((temp > 0.24) && (temp <= 0.25))
Blink LED2
else if ((temp > 0.25) && (temp <= 0.26))
Blink LED3
else if ((temp > 0.26) && (temp <= 0.27))
Blink LED4
else if (temp > 0.27)
Blink LED5
Also, notice the continuity between the ranges... example, LED2 include 0.25, but LED3 takes everything just above 0.25, up to, and including 0.26.
Something like...
if (temp <= 0.24)
Blink LED1
Blink LED2
Blink LED3
Blink LED4
Blink LED5
Hi enjunear,
Thanks a lot for the information. it really helps. Can i ask you about the adc part?
the way i write my adc part is correct?
---------- Post added at 04:54 ---------- Previous post was at 03:49 ----------
can i know how this run? How i going to write it definition?
    while(1)
        void ConvertADC(void);
        char BusyADC(void);
        temperature=ReadADC();}
closeADC();
susuying, I haven't done PIC programming in over 6 years, so I'm definitely not the one to ask about those finer details. Personally, I'd start by finding some example code, running it, and digging into it to understand how the code functions. Some simple examples on ADC sampling should come with the compiler package, I'd imagine. Failing that, I'd start searching the 'net to find code examples on your same target device (PIC MCU).
There are a lot of PIC folks on these forums, so it might be worth your time to hunt around the threads for other people with PIC code.
Sorry that I can't be more help at the detail level.
is ok enjunear.Thanks for ur help again.
---------- Post added at 05:21 ---------- Previous post was at 05:18 ----------
#include <adc.h>
#include <delays.h>
//prototype
void openADC(void);
void ConvertADC( void );
char BusyADC( void );
int ReadADC( void );
void CloseADC( void );
void initializeA(void);
void initializeE(void);
// openADC definition
void openADC()
    ADCON1=0b00001101; //AN2=1 (voltage reference configuration bit), AN0.AN1 is the analog I/O while AN2-AN15 is the digital I/o
    ADCON2=0b10010010; //right justified, 4 TAD, FOSC/32
void initializeA()
    PORTA = 0;
    LATA = 0;
    TRISA=0b01010111; //assign port A3 and A5 as the output pin
void initializeE()
    PORTE = 0;
    LATE = 0;
    TRISE=0b00000000; //assign port E0,E1 and E2 as the output pin
//start main code
void main()
    double temperature;
    initializeA(); //call port A initialization
    initializeE(); //call port E initialization
    openADC();//call adc condiguration
    LATA = 0b11111111; //turn off all lights on LATA
    LATE = 0b11111111; //turn off all lights on LATE
//    OpenADC(ADC_FOSC_32 & ADC_RIGHT_JUST & ADC_4_TAD,ADC_CH0 & ADC_INT_OFF & ADC_REF_VDD_VSS,ADC_2ANA);    // Open the ADC in the Channel 0 (RA0; AN0,RA1;RN1 as input pin) with +5V reference level (=Vdd) and 0V as Vss. AN0-AN1 as analog while AN3-AN15 as digital pin
    //ADConversion start
    ADCON0=0b00000001;  //ADCON0 in channel 1,ADOC=1 (A/D converter module is enabled)
    Delay10TCYx(5); // NOP
    ConvertADC();
    while( BusyADC() );
    temperature = ReadADC();
    //ADConversion end
    //    ConvertADC();
    //    while(BusyADC());
    //    temperature=ReadADC();
    if (temperature<=0.24)
        //LEDTris1 = 0;//Set LED Pin data direction to OUTPUT
    while(1)
    else if ((temperature>0.24)&&(temperature<=0.25))
        //LEDTris2 = 0;//Set LED Pin data direction to OUTPUT
    while(1)
    else if ((temperature>0.25)&&(temperature<=0.26))
        //LEDTris3 = 0;//Set LED Pin data direction to OUTPUT
    while(1)
    else if ((temperature>0.26)&&(temperature<=0.27))
        //LEDTris4 = 0;//Set LED Pin data direction to OUTPUT
    while(1)
    else if ((temperature>0.27)&&(temperature<=0.28))
        //LEDTris5 = 0;//Set LED Pin data direction to OUTPUT
    while(1)
i have assign the prototype and the definition properly and it can compile successfully.But why when i test it with my hardware, all the LED is blinking?
Any part of my coding is wrong?
How to troubleshoot the ADC part?how i going to know which part i need to improve again?
Please help. Thanks
