asic1984
Full Member level 5
pic16f84 problem?
hi
i have a problem with pic16f84 ...whatever program i write on it ...it always output from the ports logic 1
example: i tried this example
http://www.geocities.com/tjacodesign/picprogmanual/picprogmanual.html
with the code :
pins 0,1,2,3 should light on and off.............but it always on
i tried many examples but same problem.........even i change the pic........knowing that ic-prog is writting and verifying that code is ok
thanks for help
hi
with the code :
;ledsrun.asm
;example program with PIC16F84 µcontroller
;connect four leds with a 470 ohm series resistor to RB0 TO 3
;and a 10k / 27pF RC-oscillator
;the LEDS will light up as a running light
;written in MPASM MICROCHIP assembler
;****set up constans and variables****
INCLUDE "P16F84.INC" ;look up file for MPASM
LIST P=16F84
ERRORLEVEL -302 ;SUPPRESS BANK SELECTION MESSAGES
__config _RC_OSC&_PWRTE_ON & _WDT_OFF ;RC oscillator, power on timer
;and watchdog timer off
status equ h'03' ;status register
trisb equ h'86' ;set up register for port B
trisa equ h'85' ;set up register for port B
count1 equ h'0e' ;general purpose register
count2 equ h'0f' ;general purpose register
leds equ h'06' ;portB is 7seg display content
porta equ h'05' ;portA is not used
;****set up portA and portB****
bsf status,5 ;switch to bank1 to set up ports
movlw h'00'
movwf trisb ;portB is all output
movlw h'00'
movwf trisa ;portA is all output
bcf status,5 ;switch back to bank0 to use ports
;****main program****
start movlw b'00000001' ;load pattern into W
movwf leds ;load W into portB (switch on rightmost LED)
call delay ;wait for some time
movlw b'00000010' ;new pattern
movwf leds
call delay ;wait
movlw b'00000100' ;new pattern
movwf leds ;
call delay ;wait
movlw b'00001000' ;new pattern
movwf leds ;
call delay ;wait
goto start ;do it all over again
;****delay subroutine****
;****delay = wait (delay count value 1) x (delay count value 2) cycles****
delay movlw h'EE' ;setup delay count value 1
movwf count1 ;count1 is slow counter
loop1 decfsz count1,1 ;
goto label ;still > 0
return ;count1 < 0 so get out of the delay loop
label movlw h'EE' ;setup delay count value 2
movwf count2 ;count2 is fast counter inside count1 loop
loop2 decfsz count2,1 ;
goto loop2 ;still > 0 so stay in loop2
goto loop1 ;count1 < 0 go to loop1
end;
thanks for help
