Problem with "Package Design" in Mentor Grapgics S
deniza956
Newbie level 1
Newbie level 1
package design problems
Hello All.
We have a problem with design package in the Mentor Graphics SDD. Some complex components in the our library are made for current project only. After end of the circuit, we attempt to package a design by assistance "Package Design" option in the DesignView or Design Capture.
In most complex components (likewise founded within the bounds of progect) we don't have any similar difficulties trouth package process.
Please, explain what we do incorrect?
The result of design compile is listed below:
Packager
06:26 PM Monday, November 19, 2007
Job Name: D:\Main\Main.prj
Packager Version: 020806.00
The root of this design is at "D:\Main\top_level.sbk".
The SchematicDesignBackAnno status indicates that the
Common DataBase is not available to receive updates.
NOTE: You must be out of Design Capture Instance Edit
mode and even then you may need to reset this status
if direct updating of the CDB is intended.
!THE CDB WILL NOT BE UPDATED!
Back annotation will not take place to the Common DataBase, however a
BAM file will be created for reading purposes or processing through
BAM Plus.
The FLATNETNAMEs status indicates that the present set
of schematic netnames should be used to update the
FLATNETNAMEs.
The Disable Repackage status indicates that
Repackaging should be allowed.
The Central Library is at "D:\Library\Central_Library.lmc".
The PDBs listed in the project file will be searched to satisfy the parts
requirements of the CDB and to replace any duplicates found in the
Target PDB.
The AllowAlphaRefDes status indicates that reference
designators containing all alpha characters should be deleted
and the relevant symbols repackaged.
BAM Plus. This -y option is useful in conjunction with the -i or -m
options where the intent is only to test a new PDB against the
schematic symbols.
The cross mapping of symbol pin names to Part Number pin
numbers will be checked for packaged symbols and mapped correctly
for unpackaged symbols.
Properties that have been checked off in the Property Definition Editor
found at Library Manager/Common Properties will be checked for value
differences between the PartsDB and the non-null properties on symbols.
Those properties checked off (other than Part Number)
will not be transferred from the PartsDB to symbols.
The following properties were checked off in the Property Definition Editor:
"Value2"
"ITN"
"RPLCMT"
"PAGE_#"
"DWG_NO"
"UMD"
"MFG"
"IBIS"
"Model Suffix"
"Part Label"
"Description"
"Simulation Model"
"Rating"
"Tolerance"
"Part Number"
"Value"
"Part Name"
The present Common DataBase is up to date with the schematic
source files.
Common Data Base has been read
Target PDB Name: Integration\LocalPartsDB.pdb
Number of Part Numbers: 78
Part Numb: BC846B -> Vend Part: BC846B
Part Numb: BLM21P300SPT -> Vend Part: BLM21P300SPT
Part Numb: BSH105 -> Vend Part: BSH105
Part Numb: CAP_ELEC_CCYL_8_100/25V -> Vend Part: CAP_ELEC_CCYL_8_100/25V
Part Numb: CMI-DBW9H63F -> Vend Part: CMI-DBW9H63F
Part Numb: CY2305-1T -> Vend Part: CY2305-1T
Part Numb: CY2309ZC-1HT -> Vend Part: CY2309ZC-1HT
Part Numb: C_TANTAL_A_2.2u_10V -> Vend Part: C_TANTAL_A_2.2u_10V
Part Numb: C_TANTAL_A_10u_10V -> Vend Part: C_TANTAL_A_10u_10V
Part Numb: C_TANTAL_B_10u_16V -> Vend Part: C_TANTAL_B_10u_16V
Part Numb: C_TANTAL_D_100u_10V -> Vend Part: C_TANTAL_D_100u_10V
Part Numb: C_1n_4KV -> Vend Part: C_1n_4KV
Part Numb: C_0603_1n_25V -> Vend Part: C_0603_1n_25V
Part Numb: C_0603_10n_10V_COG -> Vend Part: C_0603_10n_10V_COG
Part Numb: C_0603_10n_25V -> Vend Part: C_0603_10n_25V
Part Numb: C_0603_100n_25V_1 -> Vend Part: C_0603_100n_25V_1
Part Numb: C_0603_270p_50V -> Vend Part: C_0603_270p_50V
Part Numb: C_0603_470p -> Vend Part: C_0603_470p
Part Numb: DS1743 -> Vend Part: DS1743
Part Numb: EPM570T144C5 -> Vend Part: EPM570T144C5
Part Numb: E28F640J3A-120 -> Vend Part: E28F640J3A-120
Part Numb: FOX924B/25.00/2.5ppm -> Vend Part: FOX924B/25.00/2.5ppm
Part Numb: HEOC31-25.00T2H1ATN -> Vend Part: HEOC31-25.00T2H1ATN
Part Numb: HEOC31-33.00T2H1ATN -> Vend Part: HEOC31-33.00T2H1ATN
Part Numb: HEOC31-66.00T2H1ATN -> Vend Part: HEOC31-66.00T2H1ATN
Part Numb: LM75AD -> Vend Part: LM75AD
Part Numb: LT1764AEQ -> Vend Part: LT1764AEQ
Part Numb: MAX825S -> Vend Part: MAX825S
Part Numb: MAX1953EUB -> Vend Part: MAX1953EUB
Part Numb: MAX3224EAP -> Vend Part: MAX3224EAP
Part Numb: MOLEX_39-29-9202 -> Vend Part: MOLEX_39-29-9202
Part Numb: MPC8541E -> Vend Part: MPC8541E
Part Numb: PBD_254_1x2 -> Vend Part: PBD_254_1x2
Part Numb: PCI_CONN_32BIT_3_3V -> Vend Part: PCI_CONN_32BIT_3_3V
Part Numb: PCI2050B -> Vend Part: PCI2050B
Part Numb: PLD-16 -> Vend Part: PLD-16
Part Numb: PLS-3 -> Vend Part: PLS-3
Part Numb: R0603_0R_5% -> Vend Part: R0603_0R_5%
Part Numb: R0603_1k_5% -> Vend Part: R0603_1k_5%
Part Numb: R0603_2k_1% -> Vend Part: R0603_2k_1%
Part Numb: R0603_2K49_1% -> Vend Part: R0603_2K49_1%
Part Numb: R0603_4.7k_5% -> Vend Part: R0603_4.7k_5%
Part Numb: R0603_5k_1% -> Vend Part: R0603_5k_1%
Part Numb: R0603_10k_5% -> Vend Part: R0603_10k_5%
Part Numb: R0603_10R_1% -> Vend Part: R0603_10R_1%
Part Numb: R0603_24R_5% -> Vend Part: R0603_24R_5%
Part Numb: R0603_27R_5% -> Vend Part: R0603_27R_5%
Part Numb: R0603_33R_5% -> Vend Part: R0603_33R_5%
Part Numb: R0603_43R_1% -> Vend Part: R0603_43R_1%
Part Numb: R0603_49.9R_1% -> Vend Part: R0603_49.9R_1%
Part Numb: R0603_75R_5% -> Vend Part: R0603_75R_5%
Part Numb: R0603_100R_1% -> Vend Part: R0603_100R_1%
Part Numb: R0603_300R_5% -> Vend Part: R0603_300R_5%
Part Numb: SLVU2.8-8 -> Vend Part: SLVU2.8-8
Part Numb: SML-D210PT -> Vend Part: SML-D210PT
Part Numb: SML-D210VT -> Vend Part: SML-D210VT
Part Numb: TI2012_09_U601 -> Vend Part: TI2012_09_U601
Part Numb: TP_1_1mm -> Vend Part: TP_1_1mm
Part Numb: UE75A202000T -> Vend Part: UE75A202000T
Part Numb: WF3 -> Vend Part: WF3
Part Numb: XRJD-1S-24-8-8-X-9B1 -> Vend Part: XRJD-1S-24-8-8-X-9B1
Part Numb: YC164-JR-071K0L -> Vend Part: YC164-JR-071K0L
Part Numb: YC164-JR-074K7L -> Vend Part: YC164-JR-074K7L
Part Numb: YC164-JR-0727RL -> Vend Part: YC164-JR-0727RL
Part Numb: 24HST1041AX -> Vend Part: 24HST1041AX
Part Numb: 24LC64I/SN -> Vend Part: 24LC64I/SN
Part Numb: 40ST1041AX -> Vend Part: 40ST1041AX
Part Numb: 74LVT16373ADGG -> Vend Part: 74LVT16373ADGG
Part Numb: 74LV08D -> Vend Part: 74LV08D
Part Numb: 88E1111RCJ -> Vend Part: 88E1111RCJ
Part Numb: 88E6097 -> Vend Part: 88E6097
Part Numb: 98DX107 -> Vend Part: 98DX107
Part Numb: 200-PIN_DDR_SO-MODULE -> Vend Part: 200-PIN_DDR_SO-MODULE
Part Numb: 597-7701-507F -> Vend Part: 597-7701-507F
Part Numb: 2011-2X03G00SB -> Vend Part: 2011-2X03G00SB
Part Numb: 8949-L1882/15S1CBLKA -> Vend Part: 8949-L1882/15S1CBLKA
Part Numb: 215877-1 -> Vend Part: 215877-1
Part Numb: 1307224_COMPACT_PCI_CONN -> Vend Part: 1307224_COMPACT_PCI_CONN
Number of Part Names: 0
Number of Part Labels: 0
Checking for value differences between non-null symbol properties and PartsDB properties,
but only for those properties checked off in the Property Definition Editor
Checking the validity of the packaging of prepackaged schematic
symbols. Only the first error in symbols having the same
Reference Designator will be reported.
PDB ERROR: The mapping of gates in the Component section
resulted in a gate composed completely of common pins.
That is, all of its pin numbers were found more than once
in the Component section. Such a gate is superfluous and
illegal and must be removed by correcting the Parts DataBase
on part number MPC8541E.
If a Parts DataBase other than the local one is corrected,
please be sure to run Packager in the overwrite mode or
Forward Annotation in the 'Replace Local Parts' mode. Otherwise, be
sure not to use these modes or the corrections will be lost.
ERROR: Bad data for Part Number: MPC8541E in the
Parts DataBase for symbols with Part Name: MPC8541E_FREESCALE and Part Label: (null).
The relevant symbols are:
on part number 98DX107.
ERROR: Bad data for Part Number: 98DX107 in the
Parts DataBase for symbols with Part Name: 98DX107_458HSBGA and Part Label: Multilayer packet processor.
2 packaging errors have been found.
For those errors that only involve the application of wrong
pin numbers, either repackage the schematic by hand or
simply remove at least one pin number per reference designator
to enable automatic packaging when you run this
procedure again.
Testing of Packaging is being terminated with 2 errors and 0 warnings.
Design has NOT been packaged.
There have been 2 errors.
Thank you for your support to solve this problems.
