kalaianand
hello friends
I designed one flyback circuit, whose input varies from 70-330 dc, i want to maintain output voltage constant 24V dc.At first i tested input voltage at 50v dc, output voltage is regulating. problem is Mosfet(IRFP460 500v,20A) is over heating, with in 10-15 sec, i used big size heat sink. when i measured Drain to source voltage during switching(30kHz), the voltage spikes are at magnitude more than 400V. i didnt use any snubber in my application. Is that problem due to not using snubber or some other?
If snubber is the problem, please guide me to design proper snubber circuit
thank u
thank u
