problem with Orcard Capture CIS and PSPICE
musnag
Newbie level 3
Newbie level 3
orcard capture
I am draw a circuit with capture cis and simulate with pspice, but sometimes got error in pspice that some nodes are floating.
Base on capture cis, I did not observe anything floating; I also tried reconnect the wire, but still have problem.
Pls someone help....
can you upload your file or send an e-mail to me I may check it
Attach the proper grounding or earthing.
Dear friend
You can use "Place Net Alias" to number all nodes in the circuit. Therefore when you run it again, on the error page you can see the floating nodes number.
Best wishes :D
the node between two capacitors is floating, you should check it.
