Problem with ntc thermistor and Aref
mshh
Full Member level 6
Full Member level 6
usa
I have problem when i read from ntc thermistor, lcd display -273 C on lcd (proteus) when i connect Aref to ground and program ADC REF to internal cap. but if i connect it to 5v and program its refernce to vcc it works fine. what is the problem?
* What ADC?
* What schematic?
* What code?
Klaus
the code to read temperature
HTML:
Chip type               : ATmega8
Program type            : Application
AVR Core Clock frequency: 8.000000 MHz
Memory model            : Small
External RAM size       : 0
Data Stack size         : 256
#include <mega8.h>
 #include <delay.h>
 #include <stdlib.h>
  #include <stdio.h>
  #include <math.h>
 #include <delay.h>
// Alphanumeric LCD functions
#include <alcd.h>
// Voltage Reference: Int., cap. on AREF
#define ADC_VREF_TYPE ((1<<REFS1) | (1<<REFS0) | (0<<ADLAR))
// Read the AD conversion result
unsigned int read_adc(unsigned char adc_input)
ADMUX=adc_input | ADC_VREF_TYPE;
// Delay needed for the stabilization of the ADC input voltage
delay_us(10);
// Start the AD conversion
ADCSRA|=(1<<ADSC);
// Wait for the AD conversion to complete
while ((ADCSRA & (1<<ADIF))==0);
ADCSRA|=(1<<ADIF);
return ADCW;
float delta,adc;
char str[16]; //allocate on lcd
float Tref=23;
 int Vo;
float R1 = 10000;
float logR2, R2, T;
float c1 = 1.009249522e-03, c2 = 2.378405444e-04, c3 = 2.019202697e-07;
void main(void)
// Func7=Out Func6=Out Func5=Out Func4=Out Func3=Out Func2=Out Func1=Out Func0=Out
// State7=0 State6=0 State5=0 State4=0 State3=0 State2=0 State1=0 State0=0
PORTB=0x00;
DDRB=0xFF;
// Port C initialization
// Func6=In Func5=In Func4=In Func3=In Func2=In Func1=In Func0=In
// State6=T State5=T State4=T State3=T State2=T State1=T State0=T
PORTC=0x00;
DDRC=0x00;
// Port D initialization// Func7=Out Func6=Out Func5=Out Func4=Out Func3=Out Func2=Out Func1=Out Func0=Out
PORTD=0x00;
DDRD=0xFF;
// ADC initialization
// ADC Clock frequency: 1000.000 kHz
// ADC Voltage Reference: AREF pin
ADMUX=ADC_VREF_TYPE & 0xff;
ADCSRA=0x83;
// Alphanumeric LCD initialization// Connections are specified in the
// Project|Configure|C Compiler|Libraries|Alphanumeric LCD menu:// RS - PORTD Bit 0// RD - PORTD Bit 1// EN - PORTD Bit 2
// D4 - PORTD Bit 4// D5 - PORTD Bit 5// D6 - PORTD Bit 6// D7 - PORTD Bit 7// Characters/line: 16
  lcd_init(16);
      lcd_clear();
while (1)
    delay_ms(100);
     Vo = read_adc(0);
    lcd_gotoxy(0,1);
    lcd_putsf("T=");
    lcd_gotoxy(2,1);
    R2 = R1 * (1023.0 / (float)Vo - 1.0);
    logR2 = log(R2);
    T = (1.0 / (c1 + c2*logR2 + c3*logR2*logR2*logR2)); // temp in kelvin
    T = T - 273.15;
   // adc = (T * 9.0)/ 5.0 + 32.0; c to fehrenhit
    ftoa(T, 0x02, str);
    lcd_puts(str);
    lcd_gotoxy(7,1);
    lcd_putchar(0xdf);    // degree
    lcd_putsf("C");
    lcd_gotoxy(1,0);
    lcd_putsf("Hello");
    delta=(adc-Tref);
    if  ( adc >=Tref && delta>=0.3)//
    PORTB.1=0;  //turn heater off
    else if (adc <=Tref && delta<=-0.3)//
    PORTB.1=1 ; //turn heater on
when Aref is connected internally it displays
did you try to debug it on your own?
--> ouptut read_Adc(0) --> to the display instead of temp
if OK then
--> ouptut VO --> to the display
if OK then
--> ouptut R2 --> to the display
and so on....
Tell us the results..
Klaus
yes i tried. i tried to display Vo but it displays 1023 and it doesn't change.
--> Then measure the voltage at VRef pin with a voltmeter.
Klaus
the voltage on Aref pin is zero
this is the problem.
Either it´s grounded outside or it´s not properly set up.
Klaus
i tested the same setup with lm35 and it works. please notice that it didn't work on simulation, i still didn't try it on practical setup
What´s the expected ARef voltage?
What´s the expected ADC0 input voltage?
What´s the expected ADConversion result?
Klaus
the expected Aref is 2.5v
the expected ADC0 input voltage is the value of the voltage divider
the expected ADC conversion is different values from 0 to 1023 related to 0 to 5v
What value?
What value?
Klaus
Vcc is 5 v so the input value to ADC0 should be from 0 to 5v according to the temperature of thermistor
for example 5 v should give 1023, 2.5v should give 512 and so on
You have a simulation tool --> simply use a voltmeter and measure the voltage.
No.
ADC_Vref is to what the ADC references (thus the name).
--> read the datasheet.
Thus 0...1023 (1024) is the range from 0V to ADC_VRef.
5V is a bad example, because it will give 1023 in any case, independent of VRef.
Klaus
Klaus
thanks , i got it i think that the ref voltage was the problem. i changed the voltage on the thermistor to 2.5 (which is the Aref voltage ) and it works
